[GRASS5] Problems compiling grass51/57 on cygwin
Buchan Milne
bgmilne at cae.co.za
Thu Oct 2 09:00:58 EDT 2003
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Radim Blazek wrote:
> On Wednesday 01 October 2003 17:44, Buchan Milne wrote:
>>There seem to be a number of other problems, especially when trying to
>>do a minimal compile ...
>>I had to add $(GISLIB) to EXTRA_LIBS for most of the stuff in lib/db,
> I have added $(GISLIB) to dbmi_client, dbmi_driver, stubs, any other?
I have it in dbmi_base and sqlp also, and display/drivers/lib
Additionally, it seems necessary to add the path to GISLIB to db/base
> If you see obvious bug, please fix it directly in CVS, if possible.
I could maybe send patches ... but I don't have cvs access from work
(only from home over dialup) which makes it a bit more difficult.
>>Oh, and shared libraries were being created without extension too ...
> SHLIB_SUFFIX in include/Make/Platform.make is not defined? configure
should
> do that, I think.
No, it's empty, even though "Cygwin environment" is found.
>>And even though I configured without tcltk, lib/form/open.c is wanting
>>to include the X headers inherited from tk.h, and wanting to link to tcl
>>libs.
> Tcltk is more or less requirement (v.digit, d.what.vect, db drivers),
> but I agree that libes and modules using that should be compiled
> conditionaly (for non interactive enviroments).
That would be nice, I really only need enough for v.net.path and r.what
and a few similar tools.
>>Similar problems with lib/ogsf/gvd.c and OpenGL ...
>>Maybe someone should try compiling with none of the optional
>>requirements, and see if they are still optional.
> But you have already tried, no?
I have X11 and tcltk enabled at present ...
>>I wanted to avoid
>>installing a whole bunch of software on my cygwin installation (which is
>>short on disk space), and was prepared to lose all the features, but it
>>seems I would have been better off repartitioning my system to make more
>>space ...
> I would prefer, if you could add conditions to source and Makefiles,
if possible.
OK, I will try ...
The first problem is there is no USE_OPENGL in include/config.h.in, and
with it, configure doesn't do anything useful (#define USE_OPENGL for
instance) with it. I don't have a working autoconf, so haven't been able
to fix configure.in.
So far, only lib/ogsf needs this, I'll probably find some more when I
get back from lunch ...
Finally, I don't know if there are problems with LD_LIBRARY_PATH on
Cygwin, but I needed to add $GISBASE/lib to $PATH in order for the html
doc extraction to work.
Regards,
Buchan
|--------------Another happy Mandrake Club member--------------|
Buchan Milne Mechanical Engineer, Network Manager
Cellphone * Work +27 82 472 2231 * +27 21 8828820x202
Stellenbosch Automotive Engineering http://www.cae.co.za
GPG Key http://ranger.dnsalias.com/bgmilne.asc
1024D/60D204A7 2919 E232 5610 A038 87B1 72D6 AC92 BA50 60D2 04A7
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQE/fCGJrJK6UGDSBKcRAlMFAJ9BSa3/JrDuqmyy1nizhV06zWYSaACeM8UA
txSUfRwAx05H+SCIK94taFQ=
=0dpV
-----END PGP SIGNATURE-----
Please click on http://www.cae.co.za/disclaimer.htm to read our
e-mail disclaimer or send an e-mail to info at cae.co.za for a copy.
