[GRASS5] [bug #2144] (grass) m.proj2 returns wrong answer if you use proj=longlat
Paul Kelly via RT
grass-bugs at intevation.de
Wed Oct 8 06:31:48 EDT 2003
guest wrote (Wed, Oct 1 2003 12:50:26):
> Subject: m.proj2 returns wrong answer if you use proj=longlat
> (same if you use proj=latlong)
> but works correctly if you use proj=ll:
> I'm a bit confused as to whether the parameters should be proj ones or
GRASS ones.
It should be the GRASS names for everything (if you insist on using
m.proj ;) ). GRASS used proj=ll back in the early '90s when the standard proj
did not allow use a 'pseudo-projection' of lat/long and everything had to be
treated as either a forward or inverse projection from/to lat/long. When
Frank made his improvements he chose to use proj=latlong or proj=longlat, so
the GRASS 'proj=ll' was left as an historical oddity. As far as I can make
out anyway that is what has happened.
> note: specifiying datum in one set of parameters but not the other is buggy.
Is this PROJ bug 368? ( http://bugzilla.remotesensing.org/show_bug.cgi?
id=368 ) I have applied a fix to the internal PROJ in the GRASS CVS that
should fix this...could you maybe try that (compile 5.3 --with-proj=no)
Paul
-------------------------------------------- Managed by Request Tracker
