[GRASS5] [bug #2149] (grass) v.out.shape does not export pgsql table in dbf format
Radim Blazek
blazek at itc.it
Wed Oct 8 09:12:47 EDT 2003
On Wednesday 08 October 2003 14:54, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2149
> Subject: v.out.shape does not export pgsql table in dbf format
> Platform: Mac OS X 10.2.8
> grass obtained from: Other (CDROM etc) Fink distribution
> (http://fink.sf.net/) grass binary for platform: Compiled from Sources
> GRASS Version: 5.0.2
> Error in dbf output in module v.out.shape.
> When I enter the db table of my postgres database linked with grass map I
> have this message: BUS ERROR
> and I have 3 files with suffix shp, shx, dbf and dbf file is empty.
> If I don't enter table=xxxxxx the v.out.shape run without error. It creates
> 3 file with dbf file with single attribute.
> Inside the program all work: I can query db data linked with vector files.
> There is an error when I want to export vector graphics with data in
> PostgreSQL table to ESRI SHAPE format
v.out.shape is using ODBC (db.connect). Does d.what.vect table= key= work?
Radim
