[GRASS5] [bug #2150] (grass) PG.IN.DBF - import error
Thierry Laronde tlaronde at polynum.org
Wed Oct 8 15:13:48 EDT 2003
I will fix this one with the others.
On Wed, Oct 08, 2003 at 06:19:08PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2150
> in module pg.in.dbf there is a BIG error.
> When it import dbf files it creates pgsql table in current db. It creates field similar DBF structure
> but there is a BIG error in floating numbers. If there is a value with decimal point the module
> pg.in.dbf always create REAL field. THIS IS AN ERROR ! Real field is limited to 6 number including
> fractions: the numbers are broken. IT must creates NUMERIC field, the only exact field for
> decimal precision. Please correct this one !!
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Thierry Laronde (Alceste) <tlaronde at polynum.org>
Key fingerprint = 0FF7 E906 FBAF FE95 FD89  250D 52B1 AE95 6006 F40C
