[GRASS5] GRASS 5.0.3 release candidate 4 (RC4) available
Bernhard Reiter
bernhard at intevation.de
Thu Oct 9 10:08:42 EDT 2003
On Thu, Oct 09, 2003 at 01:18:18PM +0200, Markus Neteler wrote:
> On Thu, Oct 09, 2003 at 12:54:43PM +0200, Bernhard Reiter wrote:
> > > ... is available for testing:
> > > http://mpa.itc.it/markus/grass50/
> > > TODO: - update NEWS.html for the release
> > > - else?
> > * The automatically created Changelog is missing the removal
> > of the apngs code (because this was no commit).
> > I suggest adding a hint manually.
> OK, we can do that but it will disappear in the next Changelog.
> Better to use a commit entry.
I'd say in general that it is _not_ a good idea to
let the cvs2changelog script overwrite old entries.
The better changelogs I know are at least controlled manually.
> > * Unfortunately src.nonGPL got partly packaged,
> > this needs to be removed from the tarball.
> Strange:
> cat src.nonGPL/CVS/Tag
> Treleasebranch_26_april_2002_5_0_0
> Why is that tagged? Did you tag it (please remove then)?
> I have just updated the tree.
Yes I haven't thought of that the tag got moved, too.
Also I believed that your packaging script might be actively
selecting the needed source, not just packaging everything. :)
Anyway I've removed the subdirectories of src.nonGPL from the branch now.
> > * I'm unsure if we should package all code that actually is not used
> > in the tarball. We still have it in the CVS.
> > Like src.garden/grass.java, unused, src.todo and some other stuff
> > from src.garden and src.contrib.
> > I suggest to not package them.
> It it should be removed from the release branch.
Do you want to do this (for exercise)?
It is easy enough:
If you have a fully checked out branch, just
use something like
cd unused
cvs remove -f
cvs commit
> > * It would be good style to create a detached signature for the
> > tarball in addition to the useful md5sums.
> > I suggest using Gnupg and a key of Markus as packager for the
> > time being.
> I have no idea how to do that - hints are welcome.
www.gnupg.org has good documentation for gnupg.
Steps (briefly):
Install an uptodate version of gpg.
Create a key if you don't have one:
http://www.gnupg.org/(de)/howtos/de/GPGMiniHowto-3.html#ss3.1
gpg --gen-key
(1024 bit is sufficient.)
Sign a file with a detached signature
gpg --detach-sign grass-5.0.3rc4_src.tar.gz
( Later and repeately:
Get the public key part signed by people to build
the web of trust. :) )
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20031009/ef33484c/attachment.bin
