[GRASS5] Announcement: v5dconvert
Wallace, Beverly T
beverly.t.wallace at lmco.com
Fri Oct 17 19:57:47 EDT 2003
GRASS community,
V5dconvert is now available in src.contrib/LM/v5dconvert.
The v5dconvert programs convert GRASS 2D raster and vector data into Vis5d 2D topography, texture, and map outline data.
The v5dconvert programs are:
g.region.v5d
Set the GRASS 2D region corresponding to a Vis5d 3D data file
r.out.v5d.texture
Convert GRASS raster data into a Vis5d texture file
r.out.v5d.topo
Convert GRASS raster data into a Vis5d topography file
v.out.v5d.map
Convert GRASS vector data into a Vis5d map outline file
See the src.contrib/LM/v5dconvert/html pages for descriptions and examples.
Vis5d+ does not need to be installed to run these GRASS programs.
However Vis5d+ is needed to view the resulting files.
I have tested v5dconvert with Solaris 9 and Red Hat Linux.
If there are any problems or questions, please let me know.
Bev Wallace
Lockheed Martin, Sunnyvale, CA, USA
