[GRASS5] C and C++ compiler changes?
Glynn Clements
glynn.clements at virgin.net
Wed Oct 22 07:21:31 EDT 2003
Bernhard Reiter wrote:
> > > As far as I can tell all the compile problems with r.terraflow are
> > > because of the #include lines.
> > > With gcc3.2 and 3.3 all #include <X.h> should be replaced with #include
> > > <X>.
> > > Also, the header strstream.h is deprecated, and should be replaced with
> > > sstream.
> I'll take it this exclusively holds for C++?
Yes.
Glynn Clements <glynn.clements at virgin.net>
