[GRASS5] mif
Thu Oct 23 04:47:48 EDT 2003
> i'm  a newer to grass, anyone can tell me how to import mapinfo
> format(MIF, MID)to grass(grass5.3)?
v.in.mif exists in 5.0.x and 5.3's source trees, and compiles, but isn't
built by default. There's probably a reason for that (buggy?).
cd src/mapdev/v.in.mif
gmake5
gmakelinks5
In GRASS 5.7, --with-gdal, use:
v.in.ogr
  http://www.remotesensing.org/ogr/drv_mitab.html
Which probably works quite well.
If you've got 5.3 compiling, you can probably get 5.7 going without too
much trouble as well. You can then export to a format 5.3 likes or stick
with 5.7.
[install GDAL first. http://www.remotesensing.org/gdal]
good luck,
Hamish
