[bug #2180] (grass) Re: [GRASS5] C and C++ compiler changes?
Glynn Clements glynn.clements at virgin.net
Thu Oct 23 19:41:32 EDT 2003
Markus Neteler wrote:
> Naive question:
> Should/can add we a test in the (G)makefile and disable certain gcc versions
> to avoid too many "bug" reports?
No.
If there are bugs in the version of gcc which ships with a particular
Linux distribution, the vendor will eventually provide an upgrade
which fixes the bug. The fixed version will probably be
indistinguishable from the broken version.
Glynn Clements <glynn.clements at virgin.net>
