[GRASS5] Re: 5.0.3 release candidate 1
    Glynn Clements
    glynn.clements at virgin.net
    Thu Sep  4 18:04:07 EDT 2003
Markus Neteler wrote:
> > > > ps -- can anything be done to get rid of all the
> > > > src/include/gis.h:35: warning: `GRASS_copyright' defined but not used
> > > > warnings?
> > For gcc, use the "unused" attribute:
> > 	#ifndef __GNUC__
> > 	#define __attribute__(x)
> > 	#endif
> > 	static const char *GRASS_copyright = "GRASS GNU GPL licensed Software"
> > 		__attribute__((unused)) ;
> Will you apply this to CVS?
Committed to HEAD; given that this merely suppresses warnings, I'm not
sure that it should go into the release branch yet (breaking gis.h
would break absolutely everything).
For good measure, I've also added:
	__attribute__((format(printf,1,2)))
to the declarations of G_fatal_error() and G_warning() in gisdefs.h,
so gcc will detect if the arguments don't match the specifiers in the
format string.
Glynn Clements <glynn.clements at virgin.net>
