[GRASS5] color table
Markus Neteler
neteler at itc.it
Mon Sep 8 08:27:07 EDT 2003
On Thu, Sep 04, 2003 at 10:04:54PM +0100, Glynn Clements wrote:
Content-Description: message body and .signature
> Markus Neteler wrote:
> > > > If possible, I would like to release 5.0.3 tomorrow or
> > > > Thursday latest (then I am out of town for more than a week).
> > > I'd like more time to look at the changes. Note that nobody has posted
> > > a comprehensive summary of what's actually changed. I'm fairly sure
> > > that some of those changes don't belong in the release branch (e.g.
> > > Mike's MinGW stuff in src/general/init/chk_dbase.c, possibly
> > > elsewhere).
> > No problem to wait. I would appreciate if the changes get reviewed.
> A few more issues:
> 1. src/tcltkgrass/module/d.grid has been updated for the bordercolor=
> option and -b/-g flags, but these aren't in the release version of
> d.grid itself. Which one is wrong?
the update was wrong - reverted.
> 2. The src/tcltkgrass/module/r.proj update introduced a typo:
> {checkbox -n {Do not preform region cropping optimization} "" -n}
> I've fixed this one in both head and release branch.
ok
> 3. The signal handling changes in
> src/general/init/grass.src
> src/general/init/init.sh
> prevent trapping SIGKILL (9) and SIGTERM (15). Not trapping SIGKILL is
> sensible enough (IIRC, this will fail on some shells), but why avoid
> trapping SIGTERM?
Seems that I didn't recall correctly the outcome of that discussion.
Readded 15 both in HEAD and release_branch.
> 4. Some of the changes seem rather extensive for something that's
> supposed to be a bug-fix release. Specifically: d.barscale, v.in.dgn,
> m.in.e00, r.los, r.spread.
Concerning r.los:
It was the "trivial" update to FP done by me (based on your
recommendations). Should be ok
> I've attached a summary of the changes.
> Glynn Clements <glynn.clements at virgin.net>
Content-Description: Changes between 5.0.2 and release branch
> src/display/d.barscale/cmd/draw_scale.c
> src/display/d.barscale/cmd/main.c
> src/display/d.barscale/cmd/mouse.c
> src/display/d.barscale/cmd/options.h
> src/tcltkgrass/module/d.barscale
> Upgrade
The old version was partially non-functional. It's rather impossible
(for me) to take out only the bug-fix part without added the
small improvement (-t flag).
> Don't trap SIGKILL, SIGTERM
SIGTERM trapped now
SIGTERM trapped now
> Add version number
> Fix for first-time use
> Change test -e -> test -r
> src/libes/proj/do_proj_nad.c
[see Paul's email]
> src/mapdev/v.in.dgn/Gmakefile
> src/mapdev/v.in.dgn/README
> src/mapdev/v.in.dgn/main.c
Minor include file fixes and
2003-01-07 11:47 radim
* main.c: stroke arc and curve, read mslink of given entity number
I don't see a problem here for 5.0.3.
> src/mapdev/v.out.e00/v.out.e00.c
2003-03-31 09:13 eric
* v.out.e00.c: Fix vector/mapset lookup. Add some type casts and
extra parens to make -Wall happy (oh, and the type casts might be
necessary on some arches).
Should be fine.
> src/misc/m.in.e00/info.c
2002-07-19 22:51 roger
* info.c, main.c: Added the list= parameter and corrected a format
that was invalid for large INFO tables
Sounds ok.
> src/raster/r.in.gdal/main.c
Relevant are:
2003-07-08 15:38 markus
* main.c: change to channel numbers instead of color name
extensions for multiband data in case subsequent channels have
identical color names (as for SAA AVHRR data)
2003-04-30 14:50 markus
* main.c: submitted compression change from Eric Miller. Added grey
color table for GDT_UInt16
2003-03-13 13:49 markus
* main.c: grey_scale_colors for Byte data, color name support for
known color names (Red, Green, Blue)
2002-11-07 17:59 markus
* main.c: use positive xy coordinates for unprojected TIFF instead
of negative xy coordinates
Here should be checked that the PROJ4 related updates did not reach
the release_branch. AFAIK Paul already verified it.
Maybe some release_branch testers could try r.in.gdal.
> -src/raster/wildfire/src/r.spread/prob_invsqr.c
> +src/raster/wildfire/src/r.spread/local_proto.h
> src/raster/wildfire/src/r.spread/cell_ptrHa.h
> src/raster/wildfire/src/r.spread/cmd_line.h
> src/raster/wildfire/src/r.spread/collect_ori.c
> src/raster/wildfire/src/r.spread/costHa.h
> src/raster/wildfire/src/r.spread/deleteHa.c
> src/raster/wildfire/src/r.spread/display.c
> src/raster/wildfire/src/r.spread/fixHa.c
> src/raster/wildfire/src/r.spread/get_minHa.c
> src/raster/wildfire/src/r.spread/insert2Ha.c
> src/raster/wildfire/src/r.spread/insertHa.c
> src/raster/wildfire/src/r.spread/main.c
> src/raster/wildfire/src/r.spread/pick_dist.c
> src/raster/wildfire/src/r.spread/pick_ignite.c
> src/raster/wildfire/src/r.spread/ram2out.c
> src/raster/wildfire/src/r.spread/replaceHa.c
> src/raster/wildfire/src/r.spread/select_linksB.c
> src/raster/wildfire/src/r.spread/spot.c
> src/raster/wildfire/src/r.spread/spread.c
> [Tidying]
> Protect headers against repeated inclusion
> Move definitions from header files to source files
> Use ANSI prototypes
> Add local_proto.h
> Remove prob_invsqr.c
Motivation:
http://grass.itc.it/pipermail/grass5/2003-March/005069.html
The old versions seemed not to work, so the fix should go
into 5.0.3.
> src/scripts/contrib/d.rast.labels/d.rast.labels
> Don't trap SIGKILL
> src/scripts/contrib/d.rast.leg/d.rast.leg
minor cosmetics, no problem I think.
> src/scripts/contrib/v.line2area/v.area2line
> src/scripts/contrib/v.line2area/v.line2area
> Use -eq instead of = (why?)
was crashing recently - I don't know why, but the fix helped.
> *** BOGUS ***
> Add bordercolor=, -b, -g
reverted.
Also done now:
- update date in
src/CMD/VERSION August -> September
NEWS.html August -> September
If there are no objections, I'll package a 5.0.3RC3 today
and produce the md5 checksum as well.
Markus
