[GRASS5] 5.0.3rc2
Glynn Clements
glynn.clements at virgin.net
Mon Sep 8 16:37:57 EDT 2003
Markus Neteler wrote:
> > ? config.log
> > ? src/CMD/next_step
> > ? src/raster/r.binfer/lex.yy.c
> > ? src/raster/r.binfer/y.tab.c
> > ? src/raster/r.binfer/y.tab.h
> > ? src/raster/r.combine/cmd/lex.yy.c
> > ? src/raster/r.combine/cmd/y.tab.c
> > ? src/raster/r.combine/cmd/y.tab.h
> > ? src/raster/r.mapcalc3/lex.yy.c
> > ? src/raster/r.mapcalc3/y.tab.c
> > ? src/raster/r.mapcalc3/y.tab.h
> > ? src/raster/r.weight/inter/lex.yy.c
> > ? src/raster/r.weight/inter/y.tab.c
> > ? src/raster/r.weight/inter/y.tab.h
> This is cleaned with
> maintainer-clean
> target (see the main Makefile) except
> config.log
> src/CMD/next_step
> Should these files be added?
config.log should be deleted by the "distclean" target; I can't
actually see how it could fail to be removed.
The Makefile should be changed to remove src/CMD/next_step directory
in either the "clean" or "distclean" targets.
Glynn Clements <glynn.clements at virgin.net>
