[GRASS5] socket server sample in programman
Daniel Isenegger disen at geo.unizh.ch
Thu Sep 11 09:41:51 EDT 2003
Hi
I try to access GRASS from a C progamm via sockets.
I found in the GRASS 5.0 Programmer's Manual on S.208 das Trivial Socket
  Server (socketServer_grass.c) example and to learn the handling I try
to  customize it to the status that:
a client process (client3.c) sends a message to Trivial Socket Server
and  the Trivial Socket Server just sends back the message.
I can do this (without GRASS) with normal C-programms (client.c and
server3.c), but with the Trivial Socket Server example I'm stuck:
- what exactly is the argument to give to the Trivial Socket  Server example
(in the description: takes a simple name for a communication channel and
  builds the full path for a socket file with that name)
- how is the host:port specified? for example in client.c it is done
explicitely:
(line 35 ff  addr.sin_port = 9836; addr.sin_addr.s_addr =
inet_addr("127.0.0.1");
thanx a lot			Dani
* A simple client-applikation that sends a string to a server and receives its answer.
#include <sys/types.h>
#include <sys/socket.h>
#include <stdio.h>
#include <netinet/in.h>
#include <sys/un.h>
#include <arpa/inet.h>
#include <unistd.h>
#define SOCKET_NAME "sockli"
#define DATA "The time has come..."
int main(void)
        int sock, len;
        int n, result;
        char buf[256] = DATA;
        struct sockaddr_un addr = {0};
        sock = socket(AF_UNIX, SOCK_DGRAM, 0);
        if(!sock)
                perror("Socket could not be created");
                exit(1);
        /* setup the address */
        /*addr.sin_family = AF_INET;
        addr.sin_addr.s_addr = inet_addr("127.0.0.1");
        len = sizeof(addr); */
 		addr.sun_family = AF_UNIX;
        strcpy(addr.sun_path, SOCKET_NAME);
        len = sizeof(addr);
        n = sendto(sock, buf, strlen(buf), 0, (struct sockaddr *)&addr, len);
        if(n != strlen(buf))
                perror("sendto failed");
                exit(1);
        memset(buf, '\0', 256);
		unlink(SOCKET_NAME);
        len = sizeof(addr);
        result = bind(sock, (struct sockaddr *)&addr, len);
        if(result < 0)
                perror("Could not bind to socket");
                exit(1);
        n = recvfrom(sock, buf, 256, 0, (struct sockaddr *)&addr, &len);
        if(n < 1)
                fprintf(stderr, "server3: received data of illigal size\n");
                exit(1);
		printf("SERVER REPLY: %s", buf);
        close(sock);
/* Begin server3.c */
/* By William D. Larry [Ellectr0n] - Saturday, August 21, 2001 */
/* Copyright  2001(c) William D. Larry <wdlarry at hotmail.com> */
/* This program code is licensed under the GLP. Please read GPL for more information */
/* here we go... */
* A simple Server-Applikation, that receives a String and answers to the client.
/* Include neccessery header files */
#include <stdio.h>
#include <sys/un.h>
#include <unistd.h>
int main(void)
        int sock, len;
        int result;
        int n;
        char buf[256];
        //struct sockaddr_in addr;
        if(!sock)
                perror("creating dgram socket");
                exit(1);
        memset(&addr, 0, sizeof(addr));
        /* set up the address */
        len = sizeof(addr);
        if(result < 0)
                perror("binding to dgram socket");
                exit(1);
		buf[n] = '\0';
        if(n < 1)
                /* received less than 1 byte... that's illigal! */
                exit(1);
       	printf("RECEIVED FROM CLIENT: %s\n", buf);
        strcpy(buf, "\n\nHallo Client\n\n");
        len = sizeof(addr);
                exit(1);
        close(sock);
        //printf("\n\nSENT: %d, LEN: %d\n\n", n, strlen(buf));
#include <stdio.h>
#include <stdlib.h>
#include <errno.h>
#include "gis.h"
int main (int argc, char *argv[])
  int listenfd, rwfd;
  char *path;
  pid_t pid;
  /* Path is built using server's name */
  // path: F-des
  if (NULL == (path = G_sock_get_fname (argv[0])))
    exit (EXIT_FAILURE);
  /* Make sure another instance isn't running */
  if (G_sock_exists (path))
    if ((listenfd = G_sock_connect (path)) != -1)
      close (listenfd);
    remove (path);
  /* Bind the socket */
  // listenfd: F-des, path: F-des
  if ((listenfd = G_sock_bind (path)) < 0)
  /* Begin listening on the socket */
  // 1: int queue length, should never be = 0
  if (G_sock_listen (listenfd, 1) != 0)
  /* Loop forever waiting for connections */
  for (;;)
    if ((rwfd = G_sock_accept (listenfd)) < 0) {
      if (errno == EINTR)
	continue;
    else
    /* Fork connection */
    // parent process: listen to socket
    // child process: process request
    // pid: pid of new child process
    if ((pid = fork()) == 0) {
      char c;
      /* child closes listenfd */
      close (listenfd);
      // rwfd: F-des, c: Zeichenvektor,aus dem Zeichen gelesen werden sollen
      // 1: Anz zu lesende bytes
      while (read (rwfd, &c, 1) > 0)
	write (rwfd, &c, 1); // schreibt 1 char von c in rwfd
      close (rwfd);
      return 0;
    else if (pid > 0) {
      /* parent closes rwfd
       * a well behaved server would limit
       * the number of forks. */
      close (rwfd);
    else
  G_free (path);
  return 0;
