[GRASS5] user maintaining 5.7
Markus Neteler neteler at itc.it
Fri Sep 12 12:33:00 EDT 2003
John,
On Fri, Sep 12, 2003 at 12:16:14PM -0400, John Gillette wrote:
> Markus,
> In INSTALL under "UPDATE OF 5.7.x", it says:
> In detail:
> make mixclean
> cd /where/your/grass50/lives/
> cvs update -dP
> cd /where/your/grass57/lives/
> cvs update -dP
> make mix
> configure ...
> make
> Should this be:
> cd /where/your/grass50/lives/  <- should this say 53?
> cvs update -dP
Generally yes.
However, top of the file there is a statement
Note: We use synonymical:
      grass50 == grass50x == grass53x
unless the 50 references are all cleaned one day.
> make mixclean                  <- move to here, in 57
> cvs update -dP
> make mix
> configure ...
> make
Yes, thanks.
> It's not clear to me what directory you are in
> when the directions start.  I think this makes it
> clear that "make mixclean" is done in 57 directory.
Right.
Updated in CVS, thanks,
 Markus
