[GRASS5] Fwd: Re: [GRASSLIST:1204] Compilation errors
Bill Dickinson Jr
wdickins at pop700.gsfc.nasa.gov
Fri Sep 12 12:56:55 EDT 2003
Hello:
I started this thread on the open email list regarding some
compilation errors I received:
> > Compilation error in module: src/general/g.region (ignored)
>> Compilation error in module: src/imagery/i.points3 (ignored)
>> Compilation error in module: src/mapdev/v.digit (ignored)
>> Compilation error in module: src/mapdev/v.in.gshhs (ignored)
>> Compilation error in module: src/mapdev/v.mkquads (ignored)
>> Compilation error in module: src/mapdev/v.proj (ignored)
>> Compilation error in module: src/misc/m.proj2 (ignored)
>> Compilation error in module: src/raster/r.in.gdal (ignored)
>> Compilation error in module: src/raster/r.proj (ignored)
>> Compilation error in module: src/raster/r.sun (ignored)
>> Compilation error in module: src/raster/r.sunmask (ignored)
>> Compilation error in module: src/sites/s.proj (ignored)
> > Compilation error in module: src.contrib/GMSL/NVIZ2.2 (ignored)
>> I used the standard configure options. I'm guessing this means that
>> none of these modules will be available to me within GRASS, so it
>> would be nice to know why there were compilation errors and how to
> > correct them.
Paul Kelly and Glynn Clements have been helping me out with this, and
suggested I need to send part of the make error log so we can figure
out what's going on. The error log is attaches as build.rtf and only
contains those parts of the build log that are relevant to the errors
listed. It is assumed that all of the errors except the last one -
NVIZ2.2 - are related to the PROJ.4 external library that I have on
my machine, so I give only one example of the suspected proj errors
in the build.rtf file.
Thanks.
Bill
Bill Dickinson
GIS Specialist
NASA Goddard Space Flight Center
Environmental & Safety Branch, Code 250
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20030912/a1f2bec0/build.obj
