[GRASS5] [bug #2098] (grass) pg.in.dbf truncating or rounding real numbers
Request Tracker
grass-bugs at intevation.de
Fri Sep 12 15:31:34 EDT 2003
this bug's URL: http://intevation.de/rt/webrt?serial_num=2098
Subject: pg.in.dbf truncating or rounding real numbers
Platform: other
grass obtained from: Other (CDROM etc)
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.2
I was importing into PostgreSQL a dbf file of points with UTM values for x and y coordinates.
These did not plot correctly in d.site.pg. I discovered that the UTM coordinates were truncated. I
had used UTM coordinates to 2 decimal places to identify coring locations. After some
experimentation, I discovered that if the value is a real number, pg.in dbf pads it with a lot of
zeros to the right. When the real number is over a total of 7 places, it rounds to the nearest 7
places when being inserted into PostgreSQL. Hence, a UTM of 7350250.57 becomes 7350251. I
have no idea what is causing this. I can see nothing obviously awry in the PostgreSQL
configuration (4 byte real numbers) or insert statement that flashes by in pg.in.dbf that should
cause this.
A workaround is to make the long real number a text field in the dbf file. It becomes a text field
in PostgreSQL, preserving all meaningful digits. However, d.site.pg will still read it correctly
when specified as an x or y coordinate.
-------------------------------------------- Managed by Request Tracker
