[GRASS5] Solaris GRASS 5.1, shared libraries, external PROJ
Wallace, Beverly T
beverly.t.wallace at lmco.com
Wed Sep 17 17:28:11 EDT 2003
Dear GRASS Developers,
I have at last successfully built GRASS 5.1 (2003_09_06) on Solaris 9. Thank you to everyone who gave me advice.
The ps/ps.map/Makefile needs Proj includes:
EXTRA_INC = $(VECT_INC) $(PROJINC)
In order to run grass51, I needed to set LD_LIBRARY_PATH to find the shared libraries in dist.$ARCH/lib and the external PROJ.4 lib. This was not mentioned in the INSTALL file.
Would it be OK to add --with-proj=PROJDIR to configure? PROJDIR is the path to PROJ.4 (above bin, include, and lib). Then configure could look for include and lib under PROJDIR and lib/proj/Makefile could use NAD2BIN = $(PROJDIR)/bin.
- Bev
Bev Wallace
Lockheed Martin, Sunnyvale, CA, USA
