[GRASS5] Solaris GRASS 5.1, shared libraries, external PROJ
    Radim Blazek
    blazek at itc.it
    Thu Sep 18 03:37:29 EDT 2003
On Wednesday 17 September 2003 23:28, Wallace, Beverly T wrote:
> Dear GRASS Developers,
> I have at last successfully built GRASS 5.1 (2003_09_06) on Solaris 9.
> Thank you to everyone who gave me advice.
> The ps/ps.map/Makefile needs Proj includes:
> EXTRA_INC = $(VECT_INC) $(PROJINC)
OK, done in cvs.
> In order to run grass51, I needed to set LD_LIBRARY_PATH to find the shared
> libraries in dist.$ARCH/lib and the external PROJ.4 lib.  This was not
> mentioned in the INSTALL file.
This is done in etc/Init.sh:
if [ ! "$LD_LIBRARY_PATH" ] ; then
  LD_LIBRARY_PATH=$GISBASE/lib
  export LD_LIBRARY_PATH
else
  LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$GISBASE/lib
fi
this section is identical to 5.0, but why it is exported only
in the first case, would not be better
else
fi
and is it necessary to test if $LD_LIBRARY_PATH is defined,
is it ':/some/path' error?
Maybe you are not running GRASS within regular session?
BTW, you can run applications without $GISRC and user mapset.
(example in GRASS++ and QGIS)
Radim
