[GRASS5] r.terraflow
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri Sep 19 05:18:16 EDT 2003
On Fri, 19 Sep 2003, Markus Neteler wrote:
> Glynn
> could you please update the release_branch if desired?
I think Helena said before that r.terraflow should not even be in the
release branch as it is a new experimental program (are the C++ compiler
changes even in the release branch?)---I agree---I think it should just be
removed from the release branch to make things simpler.
Paul
