[GRASS5] r.terraflow
Helena hmitaso at unity.ncsu.edu
Fri Sep 19 08:07:05 EDT 2003
Paul is right - r.terraflow certainly is not a bugfix but a brand new
module and if I understand the releases correctly it should go into 5.3.
Anybody who needs it right now can get the CVS HEAD GRASS
Helena
  Paul Kelly wrote:
> On Fri, 19 Sep 2003, Markus Neteler wrote:
>>Glynn
>>could you please update the release_branch if desired?
> I think Helena said before that r.terraflow should not even be in the
> release branch as it is a new experimental program (are the C++ compiler
> changes even in the release branch?)---I agree---I think it should just be
> removed from the release branch to make things simpler.
> Paul
