[GRASS5] GRASS binaries for Mac OS X
Markus Neteler neteler at itc.it
Tue Sep 23 12:44:35 EDT 2003
On Tue, Sep 23, 2003 at 12:39:10AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > I am still strying to compile GRASS 5.7 on Mac OSX.
> > At time I face the general problem that, when compiling
> > libraries, symbols from other GRASS libs are required.
> > This doesn't happen on Linux.
> Have you managed to get it working using static libraries? I recommend
> trying that first, and only trying with dynamic libraries once you
> have static libraries working.
Yes, they are working. Compilation is possible with static libs.
I have put an additional script here:
http://grass.itc.it/grass51/source/conf_scripts/macosx/
However, shared libs would reduce the size from 3xx MB to a few
MB. So I am interested in getting that working as well...
Markus
