[GRASS5] GRASS binaries for Mac OS X
Markus Neteler
neteler at itc.it
Thu Sep 25 09:51:34 EDT 2003
On Wed, Sep 24, 2003 at 04:04:54AM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > I suppose that configure could be made to check for putenv();
> > > G_putenv() would then use putenv if it is available, and its own
> > > implementation (using environ) if it isn't (although the absence of
> > > putenv() seems pretty unlikely to me).
> > May I kindly ask you to submit the relevant changes?
> Done. It now uses putenv(), setenv(), then environ, in that order, so
> environ is only used if neither putenv() nor setenv() are detected by
> configure.
Thanks. I have merged it into 5.7 CVS. Compiles as expected on Mac OSX
with dynamic libraries. Now it still fails in XDRIVER.
Markus
