[GRASS5] changing resolution - who decides
Andrea Antonello
moovida at katamail.com
Fri Apr 2 01:58:55 EST 2004
Please let me show you some tests on very small rasters and resolution
changes:
case 1:
resolution 500:
10 15 20 25
30 35 40 45
50 55 60 65
changing resolution to 1000 results in:
15 25
55 65
and real resolution ew=1000 and ns=750
the kept points are the upper right of a four group
case 2:
resolution 500:
10 15 20
30 35 40
50 55 60
10 20
50 60
and real resolution ew=750 and ns=750
the choosen points are the ones in the corners of the whole thing
Who decides the values of the new resolutions, the number of cells to use and
the values of the map to keep?
Cheers
Andrea
____________________________________________________________________________
University of Trento
Department of Civil and Environmental Engineering
Via Mesiano, 77 - Trento (ITALY)
Andrea Antonello
tel: +393288497722
fax: +390461882672
