[GRASS5] [bug #2372] (grass) display of vector fields
    Request Tracker
    grass-bugs at intevation.de
    Fri Apr  2 13:13:44 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2372
Subject: display of vector fields
Platform: GNU/Linux/i386
grass binary for platform: Compiled from Sources
GRASS Version: 5.0.2
It would be nice to have a display module for vector fields:
it takes two rasters as arguments (one for direction, one for magnitude), and it
draws arrows representing the direction and magnitude at each point (probably
only good for low resolution rasters).
That way you could use it to get a nice visual representation of wind or water
flow, and similar things.
It might also be a good thing to add the resolution drop into the program (instead
of depending on low resolution rasters) so that you could display a relatively high
resolution DEM and then overlay a vector field representing water flow (or wind,
or whatever) at a lower resolution so that there's room to draw the arrows without
them interfering with each other
-------------------------------------------- Managed by Request Tracker
