[GRASS5] [bug #2373] (grass) undefined reference in libgrass_driver.so
Request Tracker
grass-bugs at intevation.de
Fri Apr 2 13:38:00 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2373
Subject: undefined reference in libgrass_driver.so
Platform: Solaris2.X/Sparc
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 5.7_exp_2004_03_20
Hi again,
I'm trying to compile grass 5.7 from a CVS snapshot (3/20/04), and the current problem (the one I hit the wall on :p) is that make craps out with:
gcc -L/export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/lib -o /export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/driver/XDRIVER -L/export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/lib OBJ.sparc-sun-solaris2.8/Box_abs.o OBJ.sparc-sun-solaris2.8/Can_do.o OBJ.sparc-sun-solaris2.8/Client.o OBJ.sparc-sun-solaris2.8/Clr_table.o OBJ.sparc-sun-solaris2.8/Color.o OBJ.sparc-sun-solaris2.8/Draw_line.o OBJ.sparc-sun-solaris2.8/Get_w_box.o OBJ.sparc-sun-solaris2.8/Get_w_line.o OBJ.sparc-sun-solaris2.8/Get_w_pnt.o OBJ.sparc-sun-solaris2.8/Graph_Clse.o OBJ.sparc-sun-solaris2.8/Graph_Set.o OBJ.sparc-sun-solaris2.8/Panel.o OBJ.sparc-sun-solaris2.8/Plylne_abs.o OBJ.sparc-sun-solaris2.8/Polygn_abs.o OBJ.sparc-sun-solaris2.8/Raster.o OBJ.sparc-sun-solaris2.8/Raster_RGB.o OBJ.sparc-sun-solaris2.8/Respond.o OBJ.sparc-sun-solaris2.8/Serve_Xevent.o OBJ.sparc-sun-solaris2.8/Work.o OBJ.sparc-sun-solaris2.8/alloc.o -lgras
s_driver -lgrass_D -lgrass_display -lgrass_raster -lgrass_gis -lgrass_datetime -lnsl -lz -lsocket -L/usr/openwin/lib -R/usr/openwin/lib -lSM -lICE -lX11 -lsocket -lnsl -lm -lnsl -lz
/export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/lib/libgrass_driver.so: undefined reference to `nanosleep'
collect2: ld returned 1 exit status
make[4]: *** [/export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/driver/XDRIVER] Error 1
make[4]: Leaving directory `/export/home/gwurman/Codes/grass57_exp_2004_03_20/display/drivers/XDRIVER/XDRIVER24'
I can't figure out where the nanosleep reference comes from or why it's broken. Any help is appreciated.
Thanks much,
Gilead Wurman
ASU Active Tectonics
-------------------------------------------- Managed by Request Tracker
