[GRASS5] [bug #2373] (grass) undefined reference in libgrass_driver.so
Markus Neteler neteler at itc.it
Fri Apr 2 16:47:50 EST 2004
A few days later the 'nanosleep' has been removed.
So simply update the version you have from CVS.
Cheers
 Markus
On Fri, Apr 02, 2004 at 08:38:00PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2373
> Subject: undefined reference in libgrass_driver.so
> Platform: Solaris2.X/Sparc
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: 5.7_exp_2004_03_20
> Hi again,
> I'm trying to compile grass 5.7 from a CVS snapshot (3/20/04), and the current problem (the one I hit the wall on :p) is that make craps out with:
> gcc  -L/export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/lib   -o /export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/driver/XDRIVER  -L/export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/lib OBJ.sparc-sun-solaris2.8/Box_abs.o OBJ.sparc-sun-solaris2.8/Can_do.o OBJ.sparc-sun-solaris2.8/Client.o OBJ.sparc-sun-solaris2.8/Clr_table.o OBJ.sparc-sun-solaris2.8/Color.o OBJ.sparc-sun-solaris2.8/Draw_line.o OBJ.sparc-sun-solaris2.8/Get_w_box.o OBJ.sparc-sun-solaris2.8/Get_w_line.o OBJ.sparc-sun-solaris2.8/Get_w_pnt.o OBJ.sparc-sun-solaris2.8/Graph_Clse.o OBJ.sparc-sun-solaris2.8/Graph_Set.o OBJ.sparc-sun-solaris2.8/Panel.o OBJ.sparc-sun-solaris2.8/Plylne_abs.o OBJ.sparc-sun-solaris2.8/Polygn_abs.o OBJ.sparc-sun-solaris2.8/Raster.o OBJ.sparc-sun-solaris2.8/Raster_RGB.o OBJ.sparc-sun-solaris2.8/Respond.o OBJ.sparc-sun-solaris2.8/Serve_Xevent.o OBJ.sparc-sun-solaris2.8/Work.o OBJ.sparc-sun-solaris2.8/alloc.o -lgras
>  s_driver -lgrass_D -lgrass_display -lgrass_raster -lgrass_gis -lgrass_datetime -lnsl    -lz  -lsocket  -L/usr/openwin/lib -R/usr/openwin/lib -lSM -lICE -lX11 -lsocket  -lnsl -lm  -lnsl    -lz
> /export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/lib/libgrass_driver.so: undefined reference to `nanosleep'
> collect2: ld returned 1 exit status
> make[4]: *** [/export/home/gwurman/Codes/grass57_exp_2004_03_20/dist.sparc-sun-solaris2.8/driver/XDRIVER] Error 1
> make[4]: Leaving directory `/export/home/gwurman/Codes/grass57_exp_2004_03_20/display/drivers/XDRIVER/XDRIVER24'
> I can't figure out where the nanosleep reference comes from or why it's broken.  Any help is appreciated.
> Thanks much,
> Gilead Wurman
> ASU Active Tectonics
> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
