[GRASS5] bug reports for GRASS 5.7
Michael Barton
michael.barton at asu.edu
Fri Apr 2 13:48:12 EST 2004
Here are a list of things I have run into with GRASS 5.7. I suspect
that many are simple to fix. I hope it's OK to do this as a longish
digest-like list rather than many individual bug reports. If the
individual reports work better, I can do that next time.
Michael Barton
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
GRASS ERROR REPORT - GRASS 5.7 CVS 2004-03-27
ON MAC OSX 10.2.8
d.mon select/start/stop=CELL says no such monitor, can't connect. But
d.mon -l lists CELL as an available driver
v.reclass
Is there no access to interactive rule-based reclassification? Is using
a file the only option? The command seems to require either a rules
file or 'specifying a column'. But it is unclear what happens if you
specify a column. I did so and the module ran, saying it had created a
new reclassification, but there seems no specification for what is
reclassified. I'm not sure if this is a bug, but it is not running as I
might normally expect it to.
r.reclass and r.recode
There is no place for inputing a rules file in the autolaunch GUI.
However, they do not start up interactive sessions. They produce errors
saying 'no rules specified'
s.in.ascii
Actually imports ascii files to vector points (not "sites"). Also, it
ignores any values after the xy(z) dimensions. That is, no attributes
imported. This is not a bug per se, but it seems that a way to input an
ascii file with xyz dimensions, plus attributes is a good thing to
have. The name should be changed perhaps. (v.points.in.ascii?)
g.mapsets produces the following error:
Error in startup script: child killed: bus error
while executing
"exec g.mapsets -l"
invoked from within
"split [exec g.mapsets -l] " \n""
invoked from within
"lsort [split [exec g.mapsets -l] " \n"] "
invoked from within
"set tmp_msts [ lsort [split [exec g.mapsets -l] " \n"] ]"
(file "/Applications/Grass/grass57/etc/g.mapsets.tcl" line 46)
NVIZ still won't start from auto-generated GUI dialog. It will start
from command line with nviz -q
v.digit still won't accept commands for its background from the startup
GUI dialog. Here is the error.
v.digit map=national_forest bgcmd=d.rast map=public_private -n
Map does not exist.
New empty map created.
Illegal vector map name <national_forest,public_private>. Character <,>
not allowed.
ERROR: Map name not SQL compliant.
This WILL work from the command line (but not GUI dialog) if written
like this
v.digit map=national_forest bgcmd='d.rast map=public_private' -n
d.what.vect:
Will work first time in a session. But if you end the query session and
close the output box, the next time you try it it causes an error. I
think the error below, generated from using the display manager query,
is because d.what.vect is producing no output.
child killed: write on pipe with no readers
while executing
"exec d.what.vect map=subsector >@stdout 2>@stdout"
("eval" body line 1)
invoked from within
"eval "exec $cmd >@stdout 2>@stdout""
(procedure "Dm::execute" line 12)
invoked from within
"Dm::execute $cmd"
(procedure "DmVector::query" line 24)
invoked from within
"DmVector::query $sel"
("vector" arm line 2)
invoked from within
"switch $type {
raster {
DmRaster::query $sel
labels {
DmLabels::query $sel
vector ..."
(procedure "Dm::query" line 10)
invoked from within
"Dm::query"
("uplevel" body line 1)
invoked from within
"uplevel \#0 $cmd"
(procedure "Button::_release" line 18)
invoked from within
"Button::_release .mainframe.topf.tb0.bbox1.b4"
(command bound to event)
v.select
The input buttons do not update to show current location and mapset. I
don't know where they get their input. They were showing a location I
was working a session or 2 ago. Also, the check boxes are confusing.
They don't indicate which vector file they are referring to.
r.proj
Needs browse buttons to find raster maps
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040402/b38b512f/attachment.bin
