[GRASS5] bug reports for GRASS 5.7
Glynn Clements
glynn.clements at virgin.net
Fri Apr 2 14:54:49 EST 2004
Michael Barton wrote:
> d.mon select/start/stop=CELL says no such monitor, can't connect. But
> d.mon -l lists CELL as an available driver
"d.mon -l" runs mon.list, which just lists the contents of the
monitorcap file, which always contains an entry for the CELL driver.
However, in order to start it, the driver itself has to exist, and in
order to select or stop it, it has to have been started.
> g.mapsets produces the following error:
> Error in startup script: child killed: bus error
Can you run "g.mapsets -l" under a debugger and get a backtrace?
Glynn Clements <glynn.clements at virgin.net>
