[GRASS5] d.info in grass 5.7
Scott W Mitchell
Scott_Mitchell at carleton.ca
Fri Apr 2 16:35:15 EST 2004
(actually, this is probably addressed mostly to Hamish and perhaps
Glynn, since their IDs are associated with the files in question, but I
have self-doubts on my understanding of the CVS system and its logs...)
Is d.info incompletely added to the repository, or just a work in
progress? I just tried to compile GRASS 5.7 from scratch and it
stopped there looking for main()... upon examination I see there are no
source files in there, so I've removed d.info from the parent makefile
and am continuing.
I would just assume that I had caught the middle of an update, but
apparently this directory was created two days ago...
Oops, same for r.in.mat (and out) - just the directory, no source code.
Apologies if this is a really common/normal issue.
Thanks,
Scott
Scott Mitchell, Assistant Professor, Carleton University
Department of Geography & Environmental Studies, Loeb A209
Mailing: Loeb B349, 1125 Colonel By Dr., Ottawa, ON K1S 5B6 Canada
1-613-520-2600 x2695 Fax: 613-520-4301 Scott_Mitchell at carleton.ca
