[GRASS5] d.info in grass 5.7
Glynn Clements glynn.clements at virgin.net
Fri Apr 2 17:57:41 EST 2004
Scott W Mitchell wrote:
> Is d.info incompletely added to the repository, or just a work in
> progress?  I just tried to compile GRASS 5.7 from scratch and it
> stopped there looking for main()... upon examination I see there are no
> source files in there, so I've removed d.info from the parent makefile
> and am continuing.
> I would just assume that I had caught the middle of an update, but
> apparently this directory was created two days ago...
> Oops, same for r.in.mat (and out) - just the directory, no source code.
It appears that Hamish forgot to update the tools/link.conf file.
Glynn Clements <glynn.clements at virgin.net>
