[GRASS5] d.info in grass 5.7
Markus Neteler neteler at itc.it
Fri Apr 2 17:05:21 EST 2004
Scott,
I guess you forgot to run
make mix
before compiling 5.7.
Markus
On Fri, Apr 02, 2004 at 04:35:15PM -0500, Scott W Mitchell wrote:
> (actually, this is probably addressed mostly to Hamish and perhaps
> Glynn, since their IDs are associated with the files in question, but I
> have self-doubts on my understanding of the CVS system and its logs...)
> Is d.info incompletely added to the repository, or just a work in
> progress?  I just tried to compile GRASS 5.7 from scratch and it
> stopped there looking for main()... upon examination I see there are no
> source files in there, so I've removed d.info from the parent makefile
> and am continuing.
> I would just assume that I had caught the middle of an update, but
> apparently this directory was created two days ago...
> Oops, same for r.in.mat (and out) - just the directory, no source code.
> Apologies if this is a really common/normal issue.
> Thanks,
> Scott
> Scott Mitchell, Assistant Professor, Carleton University
> Department of Geography & Environmental Studies, Loeb A209
> Mailing:  Loeb B349, 1125 Colonel By Dr., Ottawa, ON K1S 5B6 Canada
> 1-613-520-2600 x2695 Fax: 613-520-4301 Scott_Mitchell at carleton.ca
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
