[GRASS5] Bug report 2 for GRASS 5.7
Michael Barton michael.barton at asu.edu
Mon Apr 5 17:50:32 EDT 2004
Here is the next series of bug reports for GRASS 5.7. Note that there
seems to be a very serious error for d.vect.chart that could cause
system problems. I didn't find any of these in the bug tracker.
Many thanks to Radim for responding rapidly on the last set I sent in.
Michael Barton
______________________________
Michael Barton, Professor & Curator
Department of Anthropology
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
++++++++++++++++++ start here  +++++++++++++++++++++++++
d.vect.chart
This EDA utility is a great idea (I suggest adding star graphs), but
something is very wrong. No graphs are drawn. After more than 5 minutes
there was nothing but constant disk access. All other activities were
slowed down enormously. I eventually lost 2 Gb disk space, was unable
to stop the disk activity and had to reboot. I. regained most of the
disk space, but still seem to have lost 180 Mb.
Bravely, I tried again with smaller file (12 records).
d.vect.chart map=temprank_SA field=1 ctype=pie
columns=MP_TOOLS,UP_TOOLS,NEOL_TOOLS sizecol=LITHICS size=20 scale=1
ocolor=black
Again, I had no graphs after 5+ minutes, but was clearly using system
resources. All other activities (including typing and using a mouse)
were greatly slowed down.
This time I was prepared. I quit GRASS and X11. Then I checked the
process viewer. d.vect.chart was still using 5-10% CPU capacity and 33%
  memory. I killed it (+/- gracefully). THEN, XDRIVER showing as using
up to 100% CPU capacity, though no memory. XDRIVER wouldn't quit
gracefully and I had to force quit it. Again lost 1.5 Gb disk space.
Got it all back this time after a reboot. I assume that the disk space
is getting tied up in memory swap, though I couldn't find any file
created or modified during operation that matches this space (checked
before reboot).
This seems like a very serious problem with a very nice addition to
GRASS.
db.select
The following command works fine in command line (though the example
given in docs is incorrect), but does not work in autogenerated GUI
db.select driver=dbf sql='select * from temprank_SA where STRATUM="SA"'
fs=|
Sorry <*> is not a valid option
Sorry <from> is not a valid option
Sorry <temprank_SA> is not a valid option
Sorry <where> is not a valid option
Sorry, <STRATUM> is not a valid parameter
g.rename
g.rename works for all map types in GRASS 5.3 and the documentation
says it works for all types in GRASS 5.7. But when I tried to rename a
vector, I got the following error:
g.rename vect=roads,roads57
WARNING: Vectors are not supported by g.rename
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040405/690d6219/attachment.bin
