[GRASS5] bug reports for GRASS 5.7 - r.proj
Radim Blazek blazek at itc.it
Wed Apr 7 10:23:43 EDT 2004
On Monday 05 April 2004 19:26, you wrote:
> On Monday, April 5, 2004, at 02:24  AM, Radim Blazek wrote:
> >> r.proj
> >> Needs browse buttons to find raster maps
> > Database and location are not known, so it is impossible to browse
> > maps.
> I was running to a meeting and answered too hastily on this. A map
> browse button should work in whatever database, location, and mapset
> are defined. If none are defined (in the other entry boxes), the
> current database, location, and mapset are used. If the user enters
> another database, location, and/or mapset, those values should be
> substituted. It would be great if v.proj also worked this way.
It is easy to say but dependencies between options do not exists.
This need extension of options/parser. Once suggested by E.G.M.
as I recall. Maybe better to write GUI for *.proj by hand.
Radim
