[GRASS5] the floating raster file format
Glynn Clements
glynn.clements at virgin.net
Wed Apr 14 02:17:22 EDT 2004
Andrea Antonello wrote:
> after a good bottle of Montpulciano D'abruzzo and seven hours (9pm Saturday to
> 4am Sunday) in the pre-eastern night, with the help of my good friend "el
> Pitero", the amazing Khexedit, the Grass sources and the r.compress command,
> we finally have the binary raster format of floating point maps in Grass.
> I'ld like to share that, since apart of the bottle of good wine it was a
> heavy experience and none should repeat it:). I hope somebody can find
> usefull what follows and give me hints or make me notice possible errors.
> Alright, let's get started:
> My explanation example is a 3x3 floating point file.
> At the begin of the file we have 4 bytes, These are the same for compressed,
> uncompressed, integer or floating, so I left them aside for now. After these
> 4 bytes, other three pairs of 4 bytes follow, which contain the address of
> each row of data in the file (this also tells us, that there is a limit in
> the dimension of raster files, even if huge). After these bytes the rows of
> data start. Each row can be simply passed through a zlib decompressor. After
> that action we have the row of data in uncompressed format. The only thing
> left to do is to get out of that stream the right dataformat. That's all,
> rather simple if you know how to do it :)
> With the help of a small example:
> The file is the following 3x3 floating point matrix:
> 10.000 20.000 30.000
> 20.000 40.000 50.000
> 30.000 50.000 60.000
> Here is the binary and decimal version:
> THE HEADER PART:
> binary: 00000100 00000000 00000000 00000000
> decimal: 4 0 0 0
> 00010001 00000000 00000000 00000000
> 17 0 0 0
> 00100100 00000000 00000000 00000000
> 36 0 0 0
> 00110111 00000000 00000000 00000000
> 55 0 0 0
> 01001010 00110001
> 74 49
> COMMENTS:
> 4 could be the number of bytes used to define the address of each row, but I
> would not bet about that.
> 17 is the adress in bytes after which the first row of data starts,
> 36 is the same for the second row and 55 for the third. 74 is the end of file.
> I noticed the last byte only now, I will try to understand it later.
> After that, the rows of data come and since we know the offset between the
> rows, we know exactly how many bytes to send through the zlib decompressor.
> Any comment or hint is very appreciated.
The above is incorrect.
The header is a single byte, equal to sizeof(long) (typically 4 on a
32-bit platform, 8 on a 64-bit platform). Then, NROWS+1 offsets are
written as longs (i.e. 4 or 8 bytes, depending upon platform) in
big-endian (Motorola) byte order.
Thus, your example is actually interpreted as:
4 sizeof(long)
0 0 0 17 offset of row 0
0 0 0 36 offset of row 1
0 0 0 55 offset of row 2
0 0 0 74 offset of end of data
See G__write_row_ptrs() in src/libes/gis/format.c for the code which
writes this data. However, note that the row offsets are initially
zero; they get overwritten later (if you're writing compressed data,
you don't know how much space it will require until you've compressed
it).
As for the format of the actual row data, see put_fp_data() in
src/libes/gis/put_row.c and RFC 1014 (the XDR specification).
Glynn Clements <glynn.clements at virgin.net>
