[GRASS5] the floating raster file format
Andrea Antonello
moovida at katamail.com
Wed Apr 14 06:59:43 EDT 2004
Thank you very much Glynn,
In fact I'm having trouble with my vision of the things. :(
You are saving me lot's of time.
Cheers
Andrea
On Wednesday 14 April 2004 08:17, you wrote:
> Andrea Antonello wrote:
> > after a good bottle of Montpulciano D'abruzzo and seven hours (9pm
> > Saturday to 4am Sunday) in the pre-eastern night, with the help of my
> > good friend "el Pitero", the amazing Khexedit, the Grass sources and the
> > r.compress command, we finally have the binary raster format of floating
> > point maps in Grass. I'ld like to share that, since apart of the bottle
> > of good wine it was a heavy experience and none should repeat it:). I
> > hope somebody can find usefull what follows and give me hints or make me
> > notice possible errors.
> > Alright, let's get started:
> > My explanation example is a 3x3 floating point file.
> > At the begin of the file we have 4 bytes, These are the same for
> > compressed, uncompressed, integer or floating, so I left them aside for
> > now. After these 4 bytes, other three pairs of 4 bytes follow, which
> > contain the address of each row of data in the file (this also tells us,
> > that there is a limit in the dimension of raster files, even if huge).
> > After these bytes the rows of data start. Each row can be simply passed
> > through a zlib decompressor. After that action we have the row of data in
> > uncompressed format. The only thing left to do is to get out of that
> > stream the right dataformat. That's all, rather simple if you know how to
> > do it :)
> > With the help of a small example:
> > The file is the following 3x3 floating point matrix:
> > 10.000 20.000 30.000
> > 20.000 40.000 50.000
> > 30.000 50.000 60.000
> > Here is the binary and decimal version:
> > THE HEADER PART:
> > binary: 00000100 00000000 00000000 00000000
> > decimal: 4 0 0 0
> > 00010001 00000000 00000000 00000000
> > 17 0 0 0
> > 00100100 00000000 00000000 00000000
> > 36 0 0 0
> > 00110111 00000000 00000000 00000000
> > 55 0 0 0
> > 01001010 00110001
> > 74 49
> > COMMENTS:
> > 4 could be the number of bytes used to define the address of each row,
> > but I would not bet about that.
> > 17 is the adress in bytes after which the first row of data starts,
> > 36 is the same for the second row and 55 for the third. 74 is the end of
> > file. I noticed the last byte only now, I will try to understand it
> > later.
> > After that, the rows of data come and since we know the offset between
> > the rows, we know exactly how many bytes to send through the zlib
> > decompressor.
> > Any comment or hint is very appreciated.
> The above is incorrect.
> The header is a single byte, equal to sizeof(long) (typically 4 on a
> 32-bit platform, 8 on a 64-bit platform). Then, NROWS+1 offsets are
> written as longs (i.e. 4 or 8 bytes, depending upon platform) in
> big-endian (Motorola) byte order.
> Thus, your example is actually interpreted as:
> 4 sizeof(long)
> 0 0 0 17 offset of row 0
> 0 0 0 36 offset of row 1
> 0 0 0 55 offset of row 2
> 0 0 0 74 offset of end of data
> See G__write_row_ptrs() in src/libes/gis/format.c for the code which
> writes this data. However, note that the row offsets are initially
> zero; they get overwritten later (if you're writing compressed data,
> you don't know how much space it will require until you've compressed
> it).
> As for the format of the actual row data, see put_fp_data() in
> src/libes/gis/put_row.c and RFC 1014 (the XDR specification).
____________________________________________________________________________
University of Trento
Department of Civil and Environmental Engineering
Via Mesiano, 77 - Trento (ITALY)
Andrea Antonello
tel: +393288497722
fax: +390461882672
