[GRASS5] New tcltkmenu
    Glynn Clements
    glynn.clements at virgin.net
    Sat Apr 17 13:29:17 EDT 2004
Sjors wrote:
> If downloaded the package with the new TclTk menu from Michael Barton at
> http://www.public.asu.edu/~cmbarton/grass.htm <http://www.public.asu.edu/%7Ecmbarton/grass.htm>
> to play around with. I untarred it etc, but the ReadMe.txt is binary
> or something, at least text viewers can't read it.
The README.txt file appearst to be in "Microsoft Unicode" format:
	$ file README.txt
	README.txt: Little-endian UTF-16 Unicode English character data, with very long lines
It's essentially UTF-16, except with a "byte-order mark" (0xfeff) at
the start of the file.
You can convert it to ASCII with:
	dd if=README.txt bs=2 skip=1 | iconv -f UTF-16 -t US-ASCII
Glynn Clements <glynn.clements at virgin.net>
