[GRASS5] r.univar and MASK
Markus Neteler neteler at itc.it
Sun Apr 18 07:21:54 EDT 2004
On Sun, Apr 18, 2004 at 04:16:18PM +1200, Hamish wrote:
> > > Everything in the r.univar script is implemented except for the
> > > extended stats (but some framework is in place for someone to
> > > continue that) and the base= map option (just use a MASK). Only
> > > minor modification of dependant scripts is needed (but definitely
> > > some).
> > AFAICT, there is no mask function implemented for GRASS 5.7 yet. If
> > I've missed it, please let me know. Thanks.
> It's there, it works.
> There's no r.mask module though (couldn't tell you why). Just use
> r.mapcalc or g.copy to make a raster map called MASK.
Up to now only raster modules with cmd/ part have been
included into 5.7. That's why r.support and r.mask are missing.
If someone adds cmd line support to r.mask, we can easily
link it.
Motivation: only with command line support the GUI pops up in 5.7.
Markus
