[GRASS5] statistics in GRASS
Scott Mitchell
smitch at mac.com
Sun Apr 18 16:29:26 EDT 2004
The problem with r.statistics is that it's limited to integer data.
The other three tools have been updated to floating point. I was going
to start by making a floating point r.statistics with at least mean,
median and mode, then work on getting other statistics in there too. I
have another old module around that is very similar to r.statistics but
with slightly different options available - it also started as integer
only and I had started making it floating point compatible - then I
discovered these other modules and wanted to stop reinventing the
wheel.
On Apr 16, 2004, at 13:16, Michael Barton wrote:
> Scott,
> I already discarded the digest that had the original thread here, so I
> may be missing your point a bit. If so, sorry. The merge of r.average,
> r.median, and r.mode was already done in r.statistics. However, if you
> are talking about working with r.univar, that would be great.
> Michael
> On Friday, April 16, 2004, at 03:01 AM, grass5-request at grass.itc.it
> wrote:
>> From: Scott W Mitchell <smitch at mac.com>
>> Date: Thu Apr 15, 2004 1:32:43 PM America/Phoenix
>> To: Hamish <hamish_nospam at yahoo.com>
>> Cc: Markus Neteler <neteler at itc.it>, grass5 at grass.itc.it
>> Subject: Re: [GRASS5] [bug #2380] (grass) unexpected '(' in r.univar
>> On Thu, 15 Apr 2004, Hamish wrote:
>> (Actually I think it was Markus who wrote:)
>>>> See also:
>>>> http://intevation.de/rt/webrt?serial_num=1848&display=History
>>>> "merge of r.average, r.median and r.mode"
>> To which Hamish said:
>>> I can't do this now. Someone else?
>>> Hamish
>> If nobody beats me to it (which would be fine!), I will be working on
>> this
>> over the summer. I said "way back" that I wanted to tackle it, but
>> haven't found the time.
>> I'm glad to see the exchange and your work on r.univar, looking at
>> that
>> code will probably really help.
>> Cheers,
>> Scott
> ______________________________
> Michael Barton, Professor & Curator
> Department of Anthropology
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
Scott Mitchell, Assistant Professor, Carleton University
Department of Geography & Environmental Studies, Loeb A209
Mailing: Loeb B349, 1125 Colonel By Dr., Ottawa, ON K1S 5B6 Canada
1-613-520-2600 x2695 Fax: 613-520-4301 Scott_Mitchell at carleton.ca
