[GRASS5] New tcltkmenu
Michael Barton
michael.barton at asu.edu
Sun Apr 18 20:25:56 EDT 2004
Sorry about this. As far as I knew it was plain text. It is hard to
tell as my computer can read many different text formats. I can run it
through a different text editor to try to change this. However, I'm
open to suggestions if you kinow of a systematic way to do this.
Michael Barton
On Saturday, April 17, 2004, at 10:29 AM, Glynn Clements wrote:
> Sjors wrote:
>> If downloaded the package with the new TclTk menu from Michael Barton
>> at
>> http://www.public.asu.edu/~cmbarton/grass.htm
>> <http://www.public.asu.edu/%7Ecmbarton/grass.htm>
>> to play around with. I untarred it etc, but the ReadMe.txt is binary
>> or something, at least text viewers can't read it.
> The README.txt file appearst to be in "Microsoft Unicode" format:
> $ file README.txt
> README.txt: Little-endian UTF-16 Unicode English character data, with
> very long lines
> It's essentially UTF-16, except with a "byte-order mark" (0xfeff) at
> the start of the file.
> You can convert it to ASCII with:
> dd if=README.txt bs=2 skip=1 | iconv -f UTF-16 -t US-ASCII
> Glynn Clements <glynn.clements at virgin.net>
____________________
C. Michael Barton, Professor
Department of Anthropology
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
