[GRASS5] New tcltkmenu
Glynn Clements
glynn.clements at virgin.net
Mon Apr 19 08:00:26 EDT 2004
Michael Barton wrote:
> Sorry about this. As far as I knew it was plain text. It is hard to
> tell as my computer can read many different text formats. I can run it
> through a different text editor to try to change this. However, I'm
> open to suggestions if you kinow of a systematic way to do this.
Doesn't the text editor have an option to select the output encoding?
Text should be in ASCII where possible, otherwise either ISO-8859-1 or
UTF-8 (I'm not sure which we should prefer although, AFAICT, all
existing occurrences of non-ASCII characters are in ISO-8859-1).
BTW, tcltkgrass/main/help.tcl contains a non-ASCII character:
Using the select button, you can choose the specific module´s manpage.
That should probably be changed to the normal ASCII single quote
character.
Glynn Clements <glynn.clements at virgin.net>
