[GRASS5] [bug #2391] (grass) r.patch: creating support files fails when 1st map isn't local
Request Tracker
grass-bugs at intevation.de
Tue Apr 27 01:11:31 EDT 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2391
Subject: r.patch: creating support files fails when 1st map isn't local
When running r.patch with "input=aspect at first_mapset,aspect at second_mapset",
building support files fails with the following errors:
r.patch: percent complete: 100%
CREATING SUPPORT FILES FOR aspect
WARNING: unable to find [aspect] in [(null)]
WARNING: category support for [aspect] in mapset [(null)] missing
grass/src/raster/r.patch/cmd/support.c header:
* creates new category and color structures from the patching
* files category and color files
* the first patch file is used as the basis. Its cats and colr
* are read into the final cats/colr structures.
* Then the other patching layers cats/colr are added to the
* final cats/colr only if these patching layers actually
* contributed new categories to the final result
thanks,
Hamish
-------------------------------------------- Managed by Request Tracker
