[GRASS5] [bug #2391] (grass) r.patch: creating support files fails when 1st map isn't local
Glynn Clements
glynn.clements at virgin.net
Tue Apr 27 10:11:55 EDT 2004
Request Tracker wrote:
> Subject: r.patch: creating support files fails when 1st map isn't local
> When running r.patch with "input=aspect at first_mapset,aspect at second_mapset",
> building support files fails with the following errors:
> r.patch: percent complete: 100%
> CREATING SUPPORT FILES FOR aspect
> WARNING: unable to find [aspect] in [(null)]
> WARNING: category support for [aspect] in mapset [(null)] missing
main() calls G_raster_map_type(), which calls G_find_cell(), which
overwrites the qualified name with the unqualified version. The
unqualified names are then passed to the support() function.
Personally, I don't think that G_raster_map_type() ought to behave
like this. If someone was willing to check that none of the code which
calls it relies upon this behaviour, we could change it to use
G_find_cell2() instead.
More generally, we should eliminate the use of G_find_file in library
functions (other than G_find_cell etc). I suspect that this problem
isn't limited to r.patch.
But, so long as G_raster_map_type() has its current behaviour, the
only solution is to duplicate the elements of opt1->answers so that
the original values are available to support().
Glynn Clements <glynn.clements at virgin.net>
