[GRASS5] i18n
Glynn Clements glynn.clements at virgin.net
Fri Apr 30 10:17:04 EDT 2004
Adam Rad-Błowski wrote:-A
> I think, after developing some of national fonts - it will be very easy
> to change GRASS installer (this is normal unix script). I could for
> example copy needed fonts after detecting, what LANG value is in the
> system.
It would be better to just add the extra fonts with new names, so that
the encoding can be chosen at run-time.
 The second - there should be made scripts to generate postscript
> with proper fonts. This is easy too. It needs only some time, what I
> have not much...:-)
As a quick hack, you should just be able to change ISOLatin1Encoding
in prolog.ps to the name of the desired encoding.
Glynn Clements <glynn.clements at virgin.net>
