[GRASS5] questions for updating tcltkgrass for 5.7
Markus Neteler
neteler at itc.it
Tue Aug 3 05:13:38 EDT 2004
On Tue, Aug 03, 2004 at 12:38:40PM +1200, Hamish wrote:
> > 1. r.univar has gone away. Now there is a r.univar.sh script and a
> > r.univar2 program module. I'm not sure what the difference is (I
> > looked at the docs for each in the CVS and GRASS 5.7 manual on line.
> > The manual only listed r.univar). Should I include one or the other or
> > both?
> It's still there, it works, no action required.
> GRASS:~> r.univar
> does the right thing.
> The program directory for the source code is called r.univar2, but if
> you look in raster/r.univar2/Makefile, it gets built as r.univar. It
> does not include extended stats yet (mode, quartiles, etc) so the old
> script (which has those) was not removed in case anyone depends on that.
> Once the C version has those, the script is gone. I'd leave the script
> off the menu.
The r.univar.sh script is definitely needed unless r.univar covers all
functionality. That's why I renamed it to r.univar.sh.
Markus
