[GRASS5] questions for updating tcltkgrass for 5.7
Michael Barton michael.barton at asu.edu
Tue Aug 3 00:29:58 EDT 2004
Hamish,
Thanks for the clarification on r.univar, r.univar2, and r.univar.sh.
Michael
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Tue, 03 Aug 2004 12:38:40 +1200
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] questions for updating tcltkgrass for 5.7
>> 1. r.univar has gone away. Now there is a r.univar.sh script and a
>> r.univar2 program module. I'm not sure what the difference is (I
>> looked at the docs for each in the CVS and GRASS 5.7 manual on line.
>> The manual only listed r.univar). Should I include one or the other or
>> both?
> It's still there, it works, no action required.
> GRASS:~> r.univar
> does the right thing.
> The program directory for the source code is called r.univar2, but if
> you look in raster/r.univar2/Makefile, it gets built as r.univar. It
> does not include extended stats yet (mode, quartiles, etc) so the old
> script (which has those) was not removed in case anyone depends on that.
> Once the C version has those, the script is gone. I'd leave the script
> off the menu.
> The Makefile in the grass51/raster/ directory just tells it which
> directories to build, not module names.
>> 5. g.mapset was done before I left, but I still need to add it.
> see  http://article.gmane.org/gmane.comp.gis.grass.devel/4354
> Hamish
