[GRASS5] 5.7: tcltkgrass: can't read "optn": no such variable
Moritz Lennert
mlennert at club.worldonline.be
Mon Aug 23 04:02:50 EDT 2004
Hello,
When I try to use the open file dialog in 5.7 tcltkgrass (for example in
v.in.ogr) I get a 'can't read "optn": no such variable' error, once I
chose a file and then click on "open":
here's the complete message:
while executing
"if {$optmulti($optn) && $optval($optn) != ""} {
append optval($optn) "," $filename
set optval($optn) $filename
invoked from within
".pw.f0.frame.optwin.fra.frame.val1.sel invoke"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke]"
(procedure "tk::ButtonUp" line 22)
invoked from within
"tk::ButtonUp .pw.f0.frame.optwin.fra.frame.val1.sel"
(command bound to event)
Is this a tcltkgrass bug, or something on my system (Debian with tcltk 8.3) ?
Moritz
