[GRASS5] 5.7: very verbose command output
Moritz Lennert mlennert at club.worldonline.be
Mon Aug 23 04:43:51 EDT 2004
>> The output of 5.7 commands is very verbose (see example below), making
>> it
>> difficult to find the requested information.
>> Is there a way to make this less verbose ?
>> Moritz
>> Example:
>> GRASS 5.7.cvs:~ > v.db.connect -p communes
>> D1/1: Vect_open_old(): name = communes mapset= mlennert update = 0
>> D1/1: Vect_set_thresh(): thresh = 0.000000
>> D1/1: dig_spidx_init()
> You have the 5.7 Debugging output turned on.
> try "g.gisenv" and you should see "DEBUG=1".
> g.gisenv set="DEBUG=0"
> will get you back to normal.
Thank you Hamish, that was it. I don't remember ever touching this
variable. Is it turned on by default ? If it is, I think that it shouldn't
be since the output can be very confusing.
Moritz
