[GRASS5] Debian and d.m/d.zoom bug - /etc/ld.so.conf
Stephan Holl
sholl at gmx.net
Wed Dec 1 01:57:10 EST 2004
Hello Markus,
On Tue, 30 Nov 2004 18:12:33 +0100 Markus Neteler <neteler at itc.it>
wrote:
> Any suggestions how to proceed? Maybe the xterm doesn't work as
> desired under Debian (why does it then with strace)?
Maybe it is a security reason, because xtrem has the s bit set. I am not
quite sure about that, but isnt it that $LD_LIBRARY_PATH is unloaded
for s-bittet programms?!
See former posting from Glynn Clements on a similar problem:
http://grass.itc.it/pipermail/grass5/2004-September/015409.html
Please correct me if I am wrong.
Cheers
Stephan
Stephan Holl
Check headers for GnuPG Key!
http://www.gdf-hannover.de
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041201/ce95a102/attachment.bin
