[GRASS5] Debian and d.m/d.zoom bug - /etc/ld.so.conf
Paolo Cavallini
cavallini at faunalia.it
Wed Dec 1 03:15:23 EST 2004
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
It seems a quite reasonable explanation.
Could anybody suggest a clean solution?
pc
At 07:57, mercoledì 01 dicembre 2004, Stephan Holl has probably written:
> Hello Markus,
> On Tue, 30 Nov 2004 18:12:33 +0100 Markus Neteler <neteler at itc.it>
> wrote:
> > Any suggestions how to proceed? Maybe the xterm doesn't work as
> > desired under Debian (why does it then with strace)?
> Maybe it is a security reason, because xtrem has the s bit set. I am not
> quite sure about that, but isnt it that $LD_LIBRARY_PATH is unloaded
> for s-bittet programms?!
> See former posting from Glynn Clements on a similar problem:
> http://grass.itc.it/pipermail/grass5/2004-September/015409.html
> Please correct me if I am wrong.
> Cheers
> Stephan
Paolo Cavallini
cavallini at faunalia.it www.faunalia.it www.faunalia.com
Piazza Garibaldi 5 - 56025 Pontedera (PI), Italy Tel: (+39)348-3801953
http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBrX2b/NedwLUzIr4RApV6AJ4lzpuUV97osdkNbPFwtCUL4MegYQCfcy7j
faAhcy0uTlY8YqB0zxv9710=
=6AT6
-----END PGP SIGNATURE-----
