[GRASS5] Debian and d.m/d.zoom bug - /etc/ld.so.conf
Markus Neteler neteler at itc.it
Wed Dec 1 07:53:39 EST 2004
On Wed, Dec 01, 2004 at 10:40:28AM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > Any suggestions how to proceed? Maybe the xterm doesn't work as
> > > > desired under Debian (why does it then with strace)?
> > > Maybe it is a security reason, because xtrem has the s bit set. I am not
> > > quite sure about that, but isnt it that $LD_LIBRARY_PATH is unloaded
> > > for s-bittet programms?!
> > > See former posting from Glynn Clements on a similar problem:
> > > http://grass.itc.it/pipermail/grass5/2004-September/015409.html
> > OK, now in CVS:
> > grass57/tools/grass-run.sh
> This should go elsewhere, e.g. lib/init. AIUI, the tools directory is
> meant for things which aren't installed, e.g. tools for building or
> maintaining GRASS rather than for using it.
OK, moved to lib/init/.
> BTW, we shouldn't need tools/getModtime any more; man/Makefile has
> been fixed to use make's built in functionality instead.
Removed in CVS.
> > Howver, the proposed xterm line causes problems:
> >  can't read "env(GISBASE)": no such variable
> > Not sure how to implement it correctly:
> > diff -u -r1.27 d.m.tcl
> > --- d.m.tcl     14 Sep 2004 16:48:38 -0000      1.27
> > +++ d.m.tcl     1 Dec 2004 09:00:14 -0000
> > @@ -85,7 +85,7 @@
> >  proc term {cmd args} {
> > -    eval exec -- xterm -e $cmd $args &
> > +    eval exec -- xterm -e $env(GISBASE)/etc/grass-run.sh $cmd $args &
> Tcl doesn't have "global" variables like most languages. It has
> "top-level" variables, but these aren't normally visible within
> procedures. You need to use "global" to make it visible, i.e.:
> 	    global env
Thanks.
d.m is now updated in CVS.
Debian users: please try again (don't forget to revert the /etc/ld.so.conf change
for testing, run ldconfig as well).
I had to modify lib/init/grass-run.sh to make it working for Fedora:
 LD_LIBRARY_PATH=$LD_LIBRARY_PATH:"$GISBASE/lib"
                 ^^^^^^^^^^^^^^^^^-added
Hopefully this problem is resolved now.
Markus
